Chip tuning?
Citat: žac poslato 21.10.2012. - 11:53
Keka, pa sto prvo nisi pit`o.... evo ima ljudi koji se razumeju.  :banghead:
Citao sam. Rumuni mi ne ulivaju poverenje za ovo i daleko su. Posto ima puno pipavog posla, ne znam ko ozbiljan hoce da se prihvati da to radi za 35 evra pa jos 5 ili vise vozila, u terenskim uslovima. Kiconix se izjasnio kako taj njihov tuning ide, tako da mi komentar mal'ko miri narucen  :whistling:
crististreulea
#151
with few additional informations:
- chip tuning will be made by dimsport dealer from Timisoara, from my town. http://www.dimsport.ro/ro/contact-dimsport/retea-dealeri . is not made by some ****, in romania are many pro's like this one http://goo.gl/EWcoR
- all modification will have warranty
- all procedure take arround 15-20 minutes for each car
- chip tuning means software update, there are no physical changes
- warranty of car is not affected
- price is for group
@Keka: in romania 35 and 80 euro are very normal price, i mean that is the price. sorry Keka, that guy screw you :(. ask him to show you dyno test from his work. i can show you a lot of pictures made by dimsport.
dimsport is not just a name www.dimsport.it , www.dimsport.com , www.dimsport.ro , www.dimsport.es
i have no interest or benefit from dimsport, i only recommend what is good for resonable price.
@Keka:
Pipav posao glasi ovako:
preko OBD i odgovarajuceg softvera, ocita se i bekapuje origanalan softver. Na isti nacin se ucita novi. Kraj. Nema razlemljivanja, kalaja, duvajlki i ostalh brutalnih alata.
#153
Ako sam dobro razumeo Kristija, za motor 1.4 MPI bi chip-tuning kostao 35 e.
A ko nam daje garanciju koju pominje?
Pejo, znaci nikakvih fizickih izmena na ECU-u nema, a dobija se oko 8KS ?
crististreulea
#154
dimsport give warranty.
becouse i trust them and i know they are pro, i can guarantee for that modification. even if i'm not payed for that :). i just know everything will be ok.
in romania chip tuning is so normal that you can do it at Dacia service :)
ECU cannot be moved from a car to another, VIN code is not identical and car will not start.
you cannot write software from 1.4mpi to 1.6mpi. or from 1.5dci 65HP to 1.5dci 70HP or 1.5dci 85HP or viceversa, are not compatible. every car must have software for his version of engine.
Peja is stok, no software :)
i have one ECU with stage 2 mounted on my car and another ECU with custom software, insane software, transform my car into a monster :). becouse i want custom software, i burn half of reservoir with testings. proof http://www.youtube.com/watch?v=yN7nU4SQ1Xs
custom software i rarely use, 8-9% diesel consumption :D http://goo.gl/17Mv7
my guess, first time will be at Kovacica.
Iako znam da se vrlo malo moze dobiti na atmosferskim motorima, javljam se kao prvi  :wave:
Ja sam prvi :P Ako uspem doci u Kovacicu
Evo ja kao treci, takodje ako uspem da dodjem u Kovacicu.   :D
Citat: žac poslato 21.10.2012. - 20:31
Jel Kristi tuniro tebi ECU?
Citat: PPejic poslato 21.10.2012. - 20:46
Prvom sledecom prilikom, ali to nema veze ni sa kim od vas.
Ja sam razumeo da se ti ne brojis u ovih 5  :ne:
Potpuno si u pravu!
crististreulea
#160
Citat: hobbista poslato 21.10.2012. - 21:49
Ko hoce chip tuning a ne moze da dodje, neka skine ECU i posalje post-expressom u Kovacicu  :laugh:
it is possible. you must convince someone to donate his car for this job. and you must send: ECU, UCH and key.
work only for 1.4mpi, 1.6mpi and 1.6 16v.
price 55 euro
ECU: http://goo.gl/ezVff  1.4 and 1.6 mpi have only one connector. diesel have 3.
UCH: http://goo.gl/NYEdL minute 1.03
key: http://goo.gl/aKpmg
this will not work for 15.dci!
Ako sve ide tako lako preko OBD, i ja se prijavljujem da probam Rumunsku mapu, pa ako je bolja od ove, nemam nista protiv.
O ceni ovde i tamo je iluzorno diskutovati, zato sto nismo tamo nego smo ovde.
Citat: crististreulea poslato 21.10.2012. - 11:14
Hello, i'm glad you finally found the chip tuning and his benefits   :jea:
I saw this link from Keka http://www.smchiptuning.com/1783/dacia-logan-1.6-90 , i was shocked! is not real what is written there! and the price ... outrageous!  it's all :bullshit:
http://www.dimsport.ro/ro/chiptuning/dacia-logan-1-6-mpi-8v-stage-normal-5
You can gain 14HP if make chip tunning, change with sport air filter, remove catalysator and lambda probe.
If change all exhoust with larger diameter, use custom http://goo.gl/WKUFw , sport came shaft, absolutly custom chip tunning software for all this modifications, you can gain extra 10 to 15 HP.
But all of this with some huge costs and consumption... damn what a consumption  :bonk:
Deklarisani dobitak u KS i Nm je tu negde kod obe kuce, da li su obe realne ili ne-neka neko odresi kesu i neka plati dyno. Dobitak od 14 KS u okviru SMPower paketa podrazumeva i mehanicke dorade, to pise sa desne strane
CitatSM Power je namjenjen za one koji hoće više snage iz motora. Za ovakav tuning potrebno je da motor i turbo budu u perfektnom stanju i SM power nije samo klasičan remap nego uključuje i promjenu nekih mehaničkih dijelova zavisno od modela,kod nekih je to samo sport filter kod nekih usis i izduv a ima i modela gdje je potrebno postaviti drugu turbinu, dizne, intercooler... Potrebno je da nas kontaktirate za svaki model pojedinačno da Vam objasnimo šta sve treba da zamijenite da bi dobili deklarisanu snagu SM powera. Cijena SM powera je cijena samo za custom remap na dynu bez cijene tih dodatnih dijelova kao i ugradnje istih. Potrebno je dodatno da Vas posavjetujemo o načinu održavanja motora kod kojih je uradjen SM power...
@crististreulea: It was a joke  :ha:
@Keka: nema potrebe da radis opet. I ako ima razlike, one su minimalne  :ne:
crististreulea
@hobbista: it is possible :)
@Keka: SM Optimum is normal chip tuning, that 10%
SM Power is custom software for those who made or want to made mechanical modification.
corect, but still very expensive :)
i payed 170 euro for custom software for my diesel. he adjusted that software 7-8 times, tested 3 days
and yes, @hobbista is right, what they did is not diffrent from what dimsport do. SMChip remove chip, wrote software, solder back. dimsport only write new software, 10-15 minutes. no diffrence, both change software,adjust air and fuel mixture.
O tome pricam. Nije nemoguce, nije  :bullshit:, jedino je razlika u ceni.
